﹎粵メм つづく 手机巴士高级顾问
沉默是金.风云在起!雄霸天下! - 精华
- 8
- 技术积分
- 0 点
- 互助积分
- 3 点
- 原创积分
- 126 点
- 爱机型号
- N81
楼主
大 中
小 发表于 2007-8-1 22:36 只看该作者
收藏本帖到: IE收藏夹 | QQ书签 | 百度搜藏 | Yahoo!
[New]精美的桌面程序Tracker for S60 3rd Edition
Tracker is a real and fully customizable desktop application. It can be integrated into system and fully substitute the built-in "Menu" application and built-in Task manager highly improving their functionality. Tracker consists of 3 main views: Desktop, TaskMan and Recent. You can switch between them using Left/Right joystick buttons.
You can place any number of sticky notes, shortcuts to applications, contacts, documents, speed dials, speed SMS, webpages, and even different actions on your desktop. You can organise all these items to any number of folders, subfolders and put them on different pages.
By using a unique intuitive navigation and "Pages pane" built into desktop you can switch between pages and folders very fast and access any item by some key presses. If it's not enough you can assign to any item, folder or even page a hotkey to access it with one key press only even if Tracker is in background.
Such approach will allow you organize your work with the device in the best way. For example you can create Business and Personal pages then place on Business page some speed dials to the most used work contacts, shortcuts to recently used documents or webpages and so on. If there are too many items you can organise them between folders and subfolders.
Tracker desktop supports device skins and its own looks can be fully customized to fit all users needs.
By using "Appearance" menu you can customize desktop look.
- Columns: you set the number of columns you want the desktop grid to have. The more columns you set the smaller the icon will be. You can set "Auto" (on default) so Tracker will determine the optimal number of columns automatically depending on your device resolution, zoom factor, and item layout.
- Item layout: you set the item appearance on desktop: Icon top, Icon left, Icon only. When the Icon only mode is selected you can see only icons on desktop and on the bottom of desktop screen you can see the selected item description. Using Icon only mode and setting large amount of columns allows you to see over one hundred items on your desktop at the same time.
- Zoom: allows you to select zoom factor of your desktop. The smaller the zoom is the smaller items will be and more information will fit the screen.
Pages pane: allows you to show or hide "Pages pane" from your desktop.
Task manager: This view shows the information about running applications. You can see what applications are running currently, switch to the needed application, get information about any running application, close some application or all applications at once. You may also see the amount of memory and disk space available on the right of the screen.
This view substitutes the built-in task manager (if enabled in options) and task selecting navigation here is the same as in the built-in one. You can select an application by using joystick or just pressing Menu key several times to select the needed application and then long press Menu key to switch to the application.
You can also select in Settings not to substitute the built-in task manager but to define your custom taskman activation hotkey, in this case both Tracker's TaskMan and the system task manager will work without conflicts at the same time (See Settings section in this documentaion for more information).
Task Switcher: Tracker's Task Switcher is an alternative way to cycle applications (requires much less key presses to switch between applications). TaskSwitcher has the same look and feel as "Alt-Tab on Windows". You can configure your own TaskSwitcher hotkey in 'Settings'. Default hotkey for it is "Shift+Menu".
One hand mode: You can define any hotkey to use with TaskSwitcher without any modifiers, e.g. to Dictaphone, Multimedia, Camera, etc key. If so TaskSwitcher will behave like the built-in one but with improved functionality.
Recent view: Recent view summarizes all important information and events in one view and allows you to perform different actions on these events. This view is in ideal harmony with Tracker's desktop and TaskMan making Tracker solid solution to control and get the most from your device.
Recent view shows recent incoming/outgoing calls, missed calls, received messages, last used applications, amount of unread messages, calendar events and todo. When you select some phone event you can dial the number or send sms/mms instantly, when you select message, you can view it and reply, when you select calendar events you see them, etc
All these events are sorted by event date. In application settings you can set up the number of items for each type to be visible on screen.
Tracker highlights:
- Fully customizable look;
- Unique and intuitive navigation;
- Real desktop;
- Ability to put on desktop: notes, applications, contacts, speed dials, sms/mms, emails, documents, links to webpages, different actions, etc;
- Ability to assign hotkeys for everything;
- Built-in extended task manager and task switcher;
- Unique "Recent" view that tracks all imprortant events and shows them in one view. Last used applications, recent calls and messages, calendar and todo events - all on one screen;
- Fast separate application launcher and "Communicator" style "New call" function;
- Autostart function;
- And a lot more unique and powerful functions to explore!
tracker_s60_3_v_1_02 BY 技风B.rar
(384.81 KB)
2007-8-1 22:36, 下载次数: 17
Tracker Edition New web 程序
